So i started building a pc and its not able to post. The led lights on my motherboard is flashing for dram. I've tried using different ram sticks by themselves and they all result in the same. I also took out the cmos battery and and cleared the rtc ram jumper as it said to do in the manual. So far nothing has worked so I'm thinking it maybe the bios just needs and update or my cpu or motherboard are bad.
My build is a ryzen 5600g on a asus tuff x570 plus motherboard.
Ram is silicon power 8gbx2 ddr4 3200. I got two of those for a total of 32gbs. The power is a thermaltake toughtpower gx2 600w. And no gpu i plan to get that later. Thanks for any help you can give.
https://linustechtips.com/topic/1523153-need-help-pc-wont-start/
That motherboard needs a bios update to run the 5600G on it , Have you made sure the bios is up to date?
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
1 hour ago, ZachNCheese said:
Try the ram sticks one by one. One faulty one could make the system not boot.
I've tried turning it on with each individual stick and it didn't work. I'm beginning to think it make have something to do with the motherboard or something
Unfortunately i have no way of checking at the moment. I can't update the bios without my cpu. My options right now seem to either return the motherboard to asus and have them send it back another motherboard or get a refund from Amazon and just buy another motherboard that is supposed to work. I unfortunately trusted the little sticker on the box that says ryzen 5000 series ready
its not a chicken and an egg problem. You can check it from the barcode thats either attached near the CPU or on the 24 pin ATX connector. Make sure that every number is legible when you send it here.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Like sorrybella said it's easy to find out.
So according to asus the bios that the motherboard shipped with is the last 4 digits on the barcode that is located between the cpu and the ram , This may be on the front of the motherboard or the back , asus doesn't specify , I would assume the back to be honest but it should be easy to check either way.
That's definately the first part of the trouble shooting process , Ignore the dram LED for now , Installing a cpu the motherboard doesn't support can do all kinds of weird stuff.
Let us know the 4 digits and we will go from there.
Edit : looks like we can see the barcode in the photo but obviously far too small to make out the numbers.
Alright I'll give an update when i get home from work. Thanks for the help I'm clueless
I think this is it. Which tells me the bios is out of date. Any suggestions? I'm considering going to a pc expert to update the bios. Or i could just return the motherboard or cpu. And thanks alot for the help
Yep, best resort besides RMA. If neither is an option, you could request Boot Kit from AMD but it does get a bit paper-laborious.
https://www.amd.com/en/support/kb/faq/rma-bkts
Well thanks that solves it. I might just return the cpu and live with a ryzen 3000 series cpu for a while. I wont be much different
Well apparently the bios that support this cpu has to be 3001 or newer so now I'm not sure what to think.
Maybe it's the cpu or motherboard.
