Hello,
I recently replaced my AIO cooler with the MSI MAG series CORELIQUID 280R Liquid Cooler, and Im not too sure what temps I had before the switch but now im running at 70*C on Idle and 88-91*C Under load, my CPU is the Ryzen 7 5800X with an Asus TUF Gaming Motherboard with an X570 chipset, Im using Core Temp and Open Hardware Monitor to look at the temps, and as im typing this my cpu is at 75*C. Im continuing to monitor my temps when doing things, Ive reapplied the thermal paste, reseated the cooler block and CPU, This cooler is one that I swapped out from my Girlfriends PC into mine and gave my old one to her because it was too big for her case so I cant swap them back to see, im wondering if these temps are normal for this cooler or if my pump is failing, thank you
https://linustechtips.com/topic/1522700-cpu-idle-temps-help/
How old is it? It might have gone bad. MSI AIO-s, especially the older ones, are known for failing, and the Coreliquid 240R and 360R were even recalled.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1522700-cpu-idle-temps-help/#findComment-16055155
23 minutes ago, Xudross said:
I replied above but forgot to add it to an actual reply
If it's under warranty, contact MSI, RMA it.
If it's not, maybe try contacting Greg Salazar, maybe he'd be interested in checking the faulty AIO out and creating content.
https://linustechtips.com/topic/1522700-cpu-idle-temps-help/#findComment-16055187
