Budget (including currency): $400
Country: Somalia
Games, programs or workloads that it will be used for: Gaming / Programming
What I got:
Kingston HyperX Fury 8 GB (1 x 8 GB) DDR4-2133 CL14 Memory
Seagate BarraCuda 500 GB 3.5" 7200 RPM Internal Hard Drive
Corsair TX650 650 W 80+ Bronze Certified ATX Power Supply
What I want to buy from Amazon:
Crucial P2 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
Cooler Master i70C 37 CFM CPU Cooler
ASRock B365M-HDV Micro ATX LGA1151 Motherboard
Gigabyte GAMING OC GeForce RTX 3050 8GB 8 GB Video Card
What I want to buy locally:
I5 8th gen CPU locally "PS" Still don't know its price.
Monitor maybe 75 or 60 Hz
So I plan to buy those mostly from Amazon since I can't find them locally. Which will cost 35$ per 1KG, so I want to know if I could fit them in HP or Dell case's Example, hp 600 g1 tower.
Also, I want to use the typical 60 Hz monitor until I can save enough for a 144 Hz one.
Any tip will be helpful.
https://linustechtips.com/topic/1522154-pc-case-help/
Those cases do not usually conform with mATX standards. As a result it is unlikely that the motherboard and PSU could be housed without extensive case modification.
See if you can find an inexpensive ATX or mATX case.
https://linustechtips.com/topic/1522154-pc-case-help/#findComment-16051532
A 3kg case cost for shipping is around 105$, excluding the case price. That's why I'm trying to find another solution.
https://linustechtips.com/topic/1522154-pc-case-help/#findComment-16051862
Are there no local shops? Or perhaps used equipment dealers? How about local classifieds?
https://linustechtips.com/topic/1522154-pc-case-help/#findComment-16051938
