New to the forum here, hello!
I have a 2.5 inch, 240 GB SSD with 25 GB of storage space left. I understand that having less free storage space slows down its performance, so what files and folders can I safely transfer to my bulk storage (1 TB HDD) so I can free up some space? Any insight would be very helpful. Thanks in advance!
https://linustechtips.com/topic/1521783-storage-management/
What do you have installed on the primary drive? You should pick the programs that you rarely use and send them to the secondary drive. I recommend reinstalls. For the long term I recommend having the download locations for your browsers and etc set to the secondary drive.
https://linustechtips.com/topic/1521783-storage-management/#findComment-16049118
To my knowledge, my operating system (Windows 10), and probably some downloaded installation files and honestly I don't know what else. I thought it would be as easy as just moving some folders over. I'll look into reinstalling some programs and the target location for browser downloads sounds like a good plan. thanks!
https://linustechtips.com/topic/1521783-storage-management/#findComment-16049166
