Budget (including currency): £1600-£1800 (GBP)
Country: UK
Games, programs or workloads that it will be used for: Current gen AAA games, 3d modelling/ game dev
It's been most of a decade since my last PC build, I've spent the last couple of years using an Alienware R17 Laptop which has since developed several issues. Primarily being that the battery starts draining while plugged in when using the graphics card, this progressed into the batterey no longer recharging to 100%. I now have a maximum of 6% battery available.
I decided it was time to let it go and get a new PC as I no longer travel as much. Like
Here is the parts list I initially ended up with:
https://uk.pcpartpicker.com/list/d6vhDq
It's been a while since I last part picked so any glaring issues being pointed out would be great.
I already have a monitor I currently use as a secondary and I would use at maximum 3 in the future.
Likely would use Windows 10 as that's what I'm used to now I have neither the time nor inclination to go down the Linux rabbit-hole atm.
Would also love advice on case fans, what I need, how many are normally used, etc.
https://linustechtips.com/topic/1521318-first-build-in-a-while/
Case with better airflow, board with better VRM's, ATX 3.0 psu, five pipe cpu cooler and an SSD with DRAM cache. You want to use Windows 11 with these Intel 13 gen cpu's due to the better scheduling with the big + little cores. The 120mm fan goes inside the back of that case for a rear exhaust fan.
PCPartPicker Part List
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  (£173.99 @ Newegg UK)
CPU Cooler: *Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler  (£41.47 @ MoreCoCo)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard  (£139.97 @ Amazon UK)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£57.34 @ Amazon UK)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£94.00 @ Amazon UK)
Video Card: *MSI VENTUS 3X OC GeForce RTX 4070 12 GB Video Card  (£589.98 @ Amazon UK)
Case: *Fractal Design Focus 2 RGB ATX Mid Tower Case  (£69.98 @ Amazon UK)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£97.99 @ Scan.co.uk)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (£8.98 @ Amazon UK)
Total: £1273.70
Generated by PCPartPicker 2023-07-23 20:04 BST+0100
A better look at those components.
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG500-BK-ARGB-Performance-CPU-Cooler-1700-AM5/2022/16252.shtml
https://www.msi.com/Graphics-Card/GeForce-RTX-4070-VENTUS-3X-12G-OC
https://www.fractal-design.com/products/cases/focus/focus-2/rgb-black-tg-clear-tint/
https://linustechtips.com/topic/1521318-first-build-in-a-while/#findComment-16045977
Country: UK
Urg a £900 RTX4070 ? It costs £600 !!
You can get much better, AM5 13600K and 4070Ti
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  (£290.37 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler  (£47.90 @ Amazon UK)
Motherboard: MSI PRO B760M-A WIFI Micro ATX LGA1700 Motherboard  (£156.48 @ Ebuyer)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL30 Memory  (£97.91 @ Amazon UK)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£89.99 @ Amazon UK)
Video Card: Palit GamingPro GeForce RTX 4070 Ti 12 GB Video Card  (£758.79 @ NeoComputers)
Case: Deepcool CC560 ATX Mid Tower Case  (£130.68 @ Newegg UK)
Power Supply: Thermaltake Toughpower GF1 PE 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£124.99 @ Amazon UK)
Total: £1697.11
Generated by PCPartPicker 2023-07-23 20:05 BST+0100
https://linustechtips.com/topic/1521318-first-build-in-a-while/#findComment-16045985
And this is what a higher end DDR5 build would look like.
CPU: *Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (£273.04 @ Box Limited)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  (£57.99 @ Amazon UK)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (£155.99 @ Amazon UK)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£104.00 @ Amazon UK)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£93.99 @ Amazon UK)
Video Card: *MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card  (£779.99 @ Scan.co.uk)
Power Supply: *Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£104.99 @ Box Limited)
Total: £1648.95
Generated by PCPartPicker 2023-07-23 21:14 BST+0100
A better look at that board, cpu and cooler.
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230494/intel-core-i513600kf-processor-24m-cache-up-to-5-10-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-BK-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16082.shtml
https://linustechtips.com/topic/1521318-first-build-in-a-while/#findComment-16046059
