Will this work for streaming ?
Go to solution Solved by filpo,
1 minute ago, Vellexar said:
what would be the bed budget 16 core cpu for it ?
no such thing
A 5950x is 450 bucks and even a 3950x might be more because of the depleting stock.
I would go for the 7900x even though its not really budget. It has only 12 cores but it has much higher clocks than the 7950x so it outperforms it
I would go for the build below
PCPartPicker Part List: https://ca.pcpartpicker.com/list/rG8znt
CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor  ($469.98 @ Amazon Canada)
CPU Cooler: ARCTIC Liquid Freezer II 420 72.8 CFM Liquid CPU Cooler  ($179.99 @ Memory Express)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($229.99 @ Memory Express)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($124.97 @ Newegg Canada)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($77.95 @ shopRBC)
Case: Lian Li LANCOOL III ATX Mid Tower Case  ($165.88 @ Vuugo)
Power Supply: Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($102.25 @ Vuugo)
Total: $1351.01
Generated by PCPartPicker 2023-07-22 14:36 EDT-0400
A friend of mine running a 13600k with a 4070ti is wanting to try to run a double pc setup for his stream. My idea was to run this something that doesn't require a gpu to make it affordable. Let me know if this would be something viable before i order and build this for him.
https://ca.pcpartpicker.com/list/LZyQ3y
https://linustechtips.com/topic/1521124-will-this-work-for-streaming/
I say he should use his main pc to stream as 40 series cards have got the av1 encoder and this secondary pc's stream would look worse than if he were just streaming off the main one (if you stream with an encoder, which he has on the gpu, it won't affect gaming performance)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
He wanted to try it as he was comfortable paying for a full secondary pc but i am trying to make him save some money that is why i am considering that build for him. ( he is the type of person that no one can change his mind )
4070ti is fine for the encoding.
If you want to go 2nd pc atleast go with a 16core cpu for max cpu preset in obs, if not stick with the GPU encoding.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
my dad's the same lol
so he really wants the secondary pc? Have you told him he can stream with his own setup?
Total: £1040.95
He is already streaming from his main pc so my guess is he doesn't need it really but wants to try it.
what would be the bed budget 16 core cpu for it ? I am trying to avoid having to get him a other gpu.
no such thing
Total: $1351.01
Total: £1040.95
