I'm I Doing It Right???
Go to solution Solved by Needfuldoer,
If you're only going to use that new 1 TB SSD as additional storage, yes. All you have to do is create a new volume in the blank space.
If you want to use it to replace your 500 gig SSD as your boot drive, you'll need to use a drive cloning utility to copy everything over and make your C: partition bigger. "Name brand" SSDs usually come with a tool that can do the job, and Acronis is always an option.
https://linustechtips.com/topic/1519369-im-i-doing-it-right/#findComment-16033155
So i should just continue pressing next on the New Simple Volume Wizard?
https://linustechtips.com/topic/1519369-im-i-doing-it-right/#findComment-16033158
If all you want is an empty 1 TB partition to store files on, yes. That won't touch your boot drive.
https://linustechtips.com/topic/1519369-im-i-doing-it-right/#findComment-16033162
