Hi everyone, so for the last month Ive been using a new water bottle, and I think the design is something that is just simple, but amazing. Its called the Zulu Ace, its a 24 ounce power coat painted insulated bottle.
ZULU Ace 24 fl oz. Black Stainless Soft Chug Bottle - Walmart.com -- walmart link
The bottom has a soft..rubber or silicon on it. And it unscrews for " easy cleaning " the top mouth pieace is an O shaped soft piece that can be removed. I LOVE this thing, the bottom coming off is literally a game changer atleast for me, cleaning, adding in ice, refilling. Its awesome. Would love to see some LTT merch like this. I reccomend atleast having the team order one to check it out.
https://linustechtips.com/topic/1519292-water-bottle-idea/
The bottom coming off seems neat. I guess it depends on how wide the top of the bottle is when you remove the lid, hard to compare since I don't have the Zulu bottle. just looking at my LTT vs pictures/video of the Zulu, the opening of the LTT seems similar in size to the Zulu when you remove the bottom. so I don't know how much easier cleaning would be, honestly after seeing the videos I'm more interested in the lid design they are using 😂 I've been looking around to see if I could find any cool lid designs that would fit the LTT bottle.
High chance of message being edited, mostly to add clarification or fix typos.
https://linustechtips.com/topic/1519292-water-bottle-idea/#findComment-16034644
So, cleaning being nice because you can take off the top and the bottom, and just clean it like a big open cylinder,
Clean the lid, and clean the bottom. Very efficient cleaning, and refilling. The top is comparable I think to most vessels with a tuber that protrudes.
https://linustechtips.com/topic/1519292-water-bottle-idea/#findComment-16037562
