First PC Build
Solved by Why_Me,
4 minutes ago, thejackattack_r said:I really like the case that you suggested but i also wanted to go with an AIO the only question I have is if I should go with Windows 10 or 11 because I've heard really bad things about win11 being buggy and crashing a lot or people not being able to do things that they want to
Windows 11 was taylor made for Intel 12 and 13 gen cpu's with P-cores and E-cores. tbh Windows 11 has it all over Windows 10 atm
