Budget (including currency): Around $2000 USD
Country: United States
Games, programs or workloads that it will be used for: Gaming mostly. Hogwarts legacy, MSFS 2020, Tarkov, Rust ETC.
Other details https://pcpartpicker.com/list/nHcVqm This is what ive put together, wanting some extra opinions $2000 is just for computer peripherals are not counted in that budget but budget is flexible if theres a good reason. feel free to ask me any questions and ill try my best to answer in a reasonable timeframe. if youre going to change parts her one request was the have the main components white (Mobo is okay being black if theres some white silkscreen or "some splash of white"
https://linustechtips.com/topic/1519014-building-pc-for-girlfriend/
Seems fine.
Obviously you're spending more on the aesthetic so theres no point trying to argue you up to a 7900XT(X) as that will defeat the purpose
Heres some possible changes
PCPartPicker Part List: https://pcpartpicker.com/list/tm4wwc
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($289.99 @ Amazon)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($55.99 @ Newegg)
Motherboard: ASRock B760 Pro RS/D4 ATX LGA1700 Motherboard  ($169.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro SL 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($79.98 @ Amazon)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Storage: Samsung 870 Evo 2 TB 2.5" Solid State Drive  ($79.98 @ Amazon)
Video Card: MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card  ($869.99 @ Newegg)
Case: Lian Li O11 Dynamic EVO ATX Mid Tower Case  ($154.50 @ Adorama)
Power Supply: Corsair RM850 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Best Buy)
Case Fan: Cooler Master SickleFlow 120 ARGB 3 In 1 62 CFM 120 mm Fans 3-Pack  ($56.91 @ Walmart)
Case Fan: Cooler Master SickleFlow 120 ARGB 62 CFM 120 mm Fan  ($19.98 @ Amazon)
Monitor: Gigabyte G27Q 27.0" 2560 x 1440 144 Hz Monitor  ($219.99 @ Newegg)
Total: $2192.28
Generated by PCPartPicker 2023-07-12 14:02 EDT-0400
6 minutes ago, Slottr said:
thank you. and yeah i was looking at some but shes kinda stuck on white. im not the biggest fan of it but what can you do. the list you sent makes sense to me. i looked at the 7900xtx but she didnt like the idea of spending the extra few hundred dollars more for a white model. and i also dont really think she would really use it to its full potential tbh
Try this ... give her some bling along with far better airflow than that 011 case offers. Those fans go inside the top of the case where an AIO would normally go.
For whatever reason this cpu cooler isn't showing up on PC Partpicker. You can also find it on Amazon.
https://www.walmart.com/ip/DeepCool-AG620-WH-ARGB-Dual-Tower-CPU-Cooler-2x-120mm-Fan-Six-Copper-Heat-Pipes-Intel-AMD-Support/2843704426
DeepCool AG620 WH ARGB Dual-Tower CPU Cooler $59.99
Low profile RAM so that it doesn't impede that dual tower cpu cooler.
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  ($349.99 @ Amazon)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($149.99 @ Newegg)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($108.99 @ Newegg)
Storage: *Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.99 @ Newegg)
Video Card: Gigabyte AERO OC GeForce RTX 4070 12 GB Video Card  ($659.99 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($99.99 @ Adorama)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Case Fan: *Lian Li UNI FAN SL V2 64.5 CFM 120 mm Fans 3-Pack  ($80.90 @ Amazon)
Monitor: *Gigabyte G24F 2 23.8" 1920 x 1080 180 Hz Monitor  ($139.99 @ Newegg)
Total: $1779.82
Generated by PCPartPicker 2023-07-12 14:19 EDT-0400
A better look at those components.
https://www.gigabyte.com/Monitor/G24F-2#kf
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230491/intel-core-i713700f-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-WH-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16083.shtml
https://lian-li.com/product/uni-fan-sl-v2/
https://lian-li.com/product/lancool-216/
Add this to that case.
https://www.newegg.com/p/1BK-07N9-00002
Lian Li LANCOOL 216 ARGB Controller and USB Module (White) $13.99
And you get this.
"The only way he could be more white is if he jizz Mayonnaise."
- John Oliver
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($319.00 @ B&H)
CPU Cooler: Thermalright Burst Assassin ARGB 66.17 CFM CPU Cooler  ($30.90 @ Amazon)
Motherboard: ASRock B650 PRO RS ATX AM5 Motherboard  ($213.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($95.99 @ Newegg)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($74.98 @ Amazon)
Video Card: MSI GAMING TRIO CLASSIC Radeon RX 7900 XT 20 GB Video Card  ($799.99 @ Newegg)
Case: Montech SKY TWO ATX Mid Tower Case  ($98.99 @ Amazon)
Total: $1993.82
Generated by PCPartPicker 2023-07-13 02:03 EDT-0400
https://www.techpowerup.com/review/montech-sky-two/
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
