Need help finding a GPU
8 minutes ago, Khnemu09 said:I can get the gpu to fit by removing the CD/DVD thing but I'm confused about the PSU I know I need to replace it but if i get a new one would i work with my old Stuff inside the computer
Also Just one note when this pc was bought after a few years I opened it and I found that they used zip ties as wire management
I know I should just buy a new pc like everyone says but i enjoy building this, sense I'm new I've only been able to Add a ram stick and replace the thermal paste and this gpu/psu was my next project, Just to explain things a bit.
That OEM build appears to only come with a 180W power supply, where I wouldn't even recommend throwing a GT 1030 or RX 6400 in it. I can't tell if its proprietary since photos online that I can find of the internals don't show the motherboard power connector. Standard is 24 pin, setup in a 2x12 configuration, generally anything of that size should fit a standard 24 pin ATX connector from a standard ATX power supply.
Overall, I wouldn't recommend throwing any dGPU in that system given the specs you're working with. Its still a decent office PC, but its not worth it as a gaming PC, even as just a baseline after throwing in a discrete GPU. There's far more sustainable ways in 2023 of getting far more powerful hardware for less. You could at least save your boot drive and RAM and throw it into a newer platform (without having to reinstall windows btw).
