GPU Cooling
Solved by SorryBella,
1 hour ago, Adrian_ae said:seeing that its not in use would anyone recommend me running it on a gtx 1080. My only concern is that would the vrms and memory need any particular cooling or can i run the card with the included vrm fan providing dedicated airflow.
Yeah, the GDDR5X runs relatively cooler than the later GDDR versions. But if you can find those small raspberry pi heatsinks for each of the memory chips that would keep it even cooler.
