I have a MSI B650 Tomahawk motherboard that I built just over a week ago, but noticed a high system temp which is quite often hotter than the rest of the system even the CPU when its idle.
Any ideas, as case fans keep getting to high RPM due to system temps which, should I just adjust fan curves up 8-10c to what I would normally use?
Shot of HWiNFO, which is same in bios temps.
https://linustechtips.com/topic/1518291-high-reported-system-temp/
Latest Bios?
Which CPU?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
2 minutes ago, BadBadali said:
What cooler are you using?
My idle is 35-45 with ambient of 25-29. EK CR240mm.
Using a dark rock 4 pro, so overkill for a 7800X3D, have 5 P14 case fans in a silent base 802.
Was going for a quite PC.
Just seems odd that the system temp is that much higher than MOSFET's and voltage regulator.
Would it just be a badly calibrated sensor and assume it is out by 8-10oC?
Eh, I don’t think it would be a bad calibration.
How many intakes and exhaust?
I think you should set your case fans to the highest setting you can take without bothering you. The sudden change in RPM is more noticeable than a constant RPM.
