I need some help understanding
Solved by Hinjima,
26 minutes ago, WolfsyMoon said:So I have a build here. https://pcpartpicker.com/list/rCD8Rv and I went very little RGB, as I don't like RGB. But what I don't udnerstand is how I connect the other cooling fans. Do I need a fan hub? I understand the CPU cooling fan header is right next to the CPU on most motherboards, but what if I am doing a AIO, do I use those headers? And for the others I want, cause cooling and all, where do they connect too? Right to the PSU? Or somewhere on the motherboard. Thanks for the help!
AIO fans should go to CPU_FAN or CPU_OPT and the pump would go to AIO_PUMP header. The rest of the fans can go to the different CHA_FAN1-2-3 headers.
I have marked them in Blue for you
