NO, The 290 alone needs 450W to run on the safe Zone, so i'd Recommend some around 650~750W because thous GCN Based GPUs Does Consume Much
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/151799-need-some-advice/#findComment-2027432
Thanks for the help and quick response man! :D
L.T.T...at your service
https://linustechtips.com/topic/151799-need-some-advice/#findComment-2027453
NO! The TDP of the GPU is 450 Watts Get a 850 watt PSU or a 1000 watt one.
No... you are completely wrong. In total those 2 draw about 400W, 450W is the suggestion from AMD/Supplier side that already take CPU in to account. A 500W PSU could run this easily. But it just a habit of mine + for safety headroom I usually add around 100-200W to the actual power draw, so a 550W or 600W is better. If you want a bit of headroom for crossfire later on then go with a 750W, a 850-1000W is usually for a 3 ways SLI/Crossfire system.
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/151799-need-some-advice/#findComment-2027578
