yea i have like 60 percent gpu usage max
lowest settings on 7900xtx
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/
Just now, r00tb33r said:
Try turning off Vsync.
If you don't mind screen tearing...
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012954
Lowest settings..... what's your per core usage on the CPU?
Besides that, you're being way too vague to really be able to help.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012955
I do.  But last time this happened to me this is how I loaded up the card by letting it render more frames than the screen can show.  I turned it back on once I knew there was nothing wrong.
This post has been ninja-edited while you weren't looking.
I'm a used parts bottom feeder.  Your loss is my gain.
I like people who tell good RGB jokes.
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012958
it is off
Setup:
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012963
I don't play Fortnite, is framerate locked in that game?
What framerate are you getting with Vsync off?
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012967
cpu usage jumps from 50-60 percent
they are all 4.3ghz
Setup:
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012968
200 on 50 percent, 450 on 65 percent
Setup:
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012972
they are all 4.3ghz
All of your cores are at 50-60% or are you saying overall usage? Fortnite prefers fewer cores and more than likely isn't running on all the cores of your CPU..
https://www.tomshardware.com/reviews/fortnite-best-performance-benchmarks,5541-6.html
If you turn graphics settings up, does GPU usage go up?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012977
That might be the limit of the game engine render loop, unless bottlenecked by the CPU.  450 is an amusingly high number.
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012978
indeed it is
im just seeing how far i can push it
Setup:
https://linustechtips.com/topic/1516574-low-gpu-usage-fortnite/#findComment-16012986
