i installed windows and then restarted my pc but when i booted it back up it showed the windows 8 loading thing and then black screen
i have also tryed reinstalling windows and the same problem occored
i have also tryed safe mode and it works fine also the screen sometimes flickers on the logon screen if i can see it but if i can i carnt do anything
things i have checked are
boots in safe mode
boots if i go into boot options and try usb
dosent boot if i just hit the power button
checked all hardware for defects
windows 7 works fine on the computer
graphics card
ram
ssd
pc specs
AMD FX 4300 4-CORE
ASRock 970-PRO3-R2
Aywun RADI A1-V10
Gigabyte GTX 760
Corsair CX-500M
Lite-On DH-24AESH
BitFenix Shinobi
Microsoft Windows 8.1
Asus Xonar DG PCI
Intel 120GB SSD 520
Corsair 8GB (2x4GB)
Western Digital 1TB
Please help
https://linustechtips.com/topic/151637-problems-with-my-pc/
try reinstalling without you gpu, then when it works install the graphics card and see if it works
Everything that's in my PC and on my desk
Intel Core i5 4670K | MSI Z87-G45 Gaming | Corsair Vengeance LP 16GB RAM | MSI GTX 770 Gaming 2GB | Corsair Obsidian 450D | Intel 530 Series 240GB SSD | Toshiba 1TB HDD | Corsair CX750M  | Scythe Mugen 4 PCGH Edition | NZXT Hue RGB Leds | 2x Corsair AF140 Quiet Edition | Corsair AF120 Performance Edition | Nanoxia Frontpanel Extension Red | AOC G2770PQU | CM Storm Quickfire Ultimate MX Brown | Corsair Vengeance M65 FPS | Corsair Vengeance 1500
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2025059
he doesn't have integrated graphics how does he do that??? also are you using a legitimate copy of windows or some knock off?
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2025093
oh yeah sorry didnt saw the FX
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2025136
ram maybe? Try to get a little speaker wich you can put on your mobo, that way you can detect the problem
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2025147
yeah but I think it's worth a try, everything ok in bios?
i think that only works pre windows loads
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2025232
this sounds like a driver isue. this may be a longshot but when you try to reinstal WIN(windows) you are given the option to preeinsatal drivers. Have an USB drive with the unziped GFX driver file on it and try to install the driver from the WIN install. But it is posible the WIN my not let you, WIN is picky.  I dont have much exprince with WIN 8 or later so my abality to give advice on this is limited.
I will do the best I can to help in any way. However I am not all knowing and realize that I can be wrong. If you know something I said is not factual please speak up and provide myself and otters reading reading the thread with the facts proving it. I'm not just here to help others learn I'm also here to learn myself. "An investment in knowledge always pays the best interest." Benjamin Franklin
https://linustechtips.com/topic/151637-problems-with-my-pc/#findComment-2027769
