Budget (including currency): 800cad
Country: Canada
Games, programs or workloads that it will be used for: Genshin valorant fornite cod rocket league modded minecraft some programming
Other details: I would prefer a pc that i can keep for like 10 years without having the need to change it got 2 ideas already
1.https://ca.pcpartpicker.com/list/nf8KFgCPU:
Intel Core i3-12100F 3.3 GHz Quad-Core Processor  ($125.50 @ shopRBC)
Motherboard: *ASRock B660M-HDV Micro ATX LGA1700 Motherboard  ($94.99 @ Newegg Canada)
Memory: *TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Newegg Canada)
Storage: *Timetec 35TTFP6PCIE 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($51.99 @ Amazon Canada)
Video Card: ASRock Challenger D OC Radeon RX 5700 XT 8 GB Video Card  ($150.00) Used
Case: Deepcool CC560 ATX Mid Tower Case  ($59.50 @ Vuugo)
Power Supply: *Deepcool PK600D 600 W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Canada Computers)
Monitor: LG 24GL600F-B 23.6" 1920 x 1080 144 Hz Monitor  ($159.99 @ Canada Computers)
Total: $746.93
2.PCPartPicker Part List: https://ca.pcpartpicker.com/list/FXvVtn
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  ($126.70 @ Amazon Canada)
Motherboard: ASRock B450M PRO4 R2.0 Micro ATX AM4 Motherboard  ($77.24 @ Vuugo)
Total: $730.38
https://linustechtips.com/topic/1516190-pc-build-come-help/
Country: Canada
Total: $746.93
Total: $730.38
personally, I would go with the r5 5500 (even if it's an i3 but it's a 4c 8t). and if you can go to b550 mbo
https://linustechtips.com/topic/1516190-pc-build-come-help/#findComment-16009921
So, I would go for the intel build, as it has a better upgrade path, but I would go for the Ryzen build if you plan not to upgrade (which looks like, you do).
I do not really know how either of those will last 10 years, but because the R5 is faster (multi core) than the i3, I think that you will have more luck with the R5, in terms of longevity. Then again, your games rather single core performance over multicore, so if you are confident enough to say that you will be playing them for the next 10 years (which is not even virtually true, trust me) you should go with the i3.
My conclusion will be going for the Ryzen 5 5500 system. It has more cores, more threads. It can overclock and it will be a great CPU in your system for the years to come. But for it to last 10 years, you should be extremely lucky. At most this will last for another 4 years, if the recent competition between AMD and intel is anything to go by. The CPUs that could last 10 years were the CPUs that came after the release of the Core architecture in 2006 until somewhere after the release of the Sandy Bridge architecture. Innovation was rather slow back then, as it took intel another 5 generations to remove the quad core from it's high end consumer grade hardware.
https://linustechtips.com/topic/1516190-pc-build-come-help/#findComment-16009922
I do plan to upgrade just dont whant to completely redo my build whenever iits time upgrade btw i might exaggerated a little bit just meant for it to last at least over 5 years
https://linustechtips.com/topic/1516190-pc-build-come-help/#findComment-16009930
Okay, go intel and upgrade it to an i9 or an i7 later that should make it last longer, alternatively you can go AMD and get a 5800X3D.
https://linustechtips.com/topic/1516190-pc-build-come-help/#findComment-16009939
