Budget (including currency): £1600
Country: uk
Games, programs or workloads that it will be used for: all types nothing specific
Other details:  I’ve been on here lots asking about stuff I’ve came up with but I have no clue. So I was wondering what the best pc I could get with £1600 I’d rather it been as functional as possible I’m not bothered about rgb. Thanks in advance.
https://linustechtips.com/topic/1516183-help-me/
Country: uk
you say nothing specifc, but you should give atleast examples of programs or workloads you would possibly run...do you use/work with photoshop? blender? CAD? CAM? making videos?
https://linustechtips.com/topic/1516183-help-me/#findComment-16009809
Country: uk
I have a perfect list here for you. It will allow you to play any game you want and do whatever else you need it to do. I also spared you the RGB stuff.
https://uk.pcpartpicker.com/list/ZjYJFg
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (£263.99 @ Amazon UK)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (£44.90 @ Amazon UK)
Motherboard: Gigabyte X570S UD ATX AM4 Motherboard  (£158.47 @ Ebuyer)
Memory: Kingston FURY Renegade 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£78.04 @ Box Limited)
Storage: ADATA XPG GAMMIX S70 Blade 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£97.72 @ NeoComputers)
Video Card: MSI GAMING X TRIO Radeon RX 6950 XT 16 GB Video Card  (£709.30 @ Amazon UK)
Case: Fractal Design Pop Air ATX Mid Tower Case  (£76.36 @ NeoComputers)
Power Supply: MSI MPG A850GF 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£119.99 @ AWD-IT)
Case Fan: Fractal Design Aspect 14 41 CFM 140 mm Fan  (£18.46 @ Scan.co.uk)
Total: £1585.69
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1516183-help-me/#findComment-16009810
Oh sorry my bad meant to put all types of gaming didn’t realise I missed that out.
https://linustechtips.com/topic/1516183-help-me/#findComment-16009860
Country: uk
If gaming is involved then knowing your resolution would be a big help.
https://linustechtips.com/topic/1516183-help-me/#findComment-16009866
Total: £1585.69
Thanks this looks good, but what would be the Intel equivalent of this.
would it also be more beneficial to go next gen cpu and ram or not.
https://linustechtips.com/topic/1516183-help-me/#findComment-16009869
1440p I was looking for
I can't fit a 1440P in here without taking a hit on frame rates for more demanding games but this Gigabyte 1080P has received rave reviews since it was released.  btw that 120mm Arctic fan goes inside the back of that case for an exhaust fan.
PCPartPicker Part List
CPU: *Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (£277.98 @ Overclockers.co.uk)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  (£57.99 @ Amazon UK)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard  (£139.00 @ Computer Orbit)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£95.98 @ Box Limited)
Video Card: *Asus DUAL OC GeForce RTX 4070 12 GB Video Card  (£584.06 @ NeoComputers)
Case: *Fractal Design Focus 2 RGB ATX Mid Tower Case  (£76.98 @ Amazon UK)
Power Supply: *MSI MPG A750GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£94.44 @ Amazon UK)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  (£99.95 @ Amazon UK)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (£9.00 @ Computer Orbit)
Monitor: *Gigabyte G24F 2 23.8" 1920 x 1080 180 Hz Monitor  (£159.98 @ Scan.co.uk)
Total: £1595.36
Generated by PCPartPicker 2023-06-28 22:15 BST+0100
A better look at those components.
https://www.gigabyte.com/Monitor/G24F-2#kf
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://www.intel.com/content/www/us/en/products/sku/230494/intel-core-i513600kf-processor-24m-cache-up-to-5-10-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-BK-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16082.shtml
https://www.westerndigital.com/products/internal-drives/wd-black-sn770-nvme-ssd#WDS200T3X0E
https://www.asus.com/us/motherboards-components/graphics-cards/dual/dual-rtx4070-o12g/
https://www.fractal-design.com/products/cases/focus/focus-2/rgb-black-tg-clear-tint/
https://linustechtips.com/topic/1516183-help-me/#findComment-16009897
Total: £1595.36
Sorry the 1600 is just for the pc the monitor is separate. You also left out the ram in this build
https://linustechtips.com/topic/1516183-help-me/#findComment-16009907
Good catch ^^ ... RAM is always a plus 😄
This runs slightly over budget.
CPU: *Intel Core i5-13400F 2.5 GHz 10-Core Processor  (£188.00 @ Amazon UK)
CPU Cooler: *Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler  (£43.77 @ NeoComputers)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£63.26 @ Amazon UK)
Video Card: *MSI VENTUS 3X OC GeForce RTX 4070 Ti 12 GB Video Card  (£795.00 @ Computer Orbit)
Power Supply: *NZXT C850 (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£106.00 @ MoreCoCo)
Total: £1616.94
Generated by PCPartPicker 2023-06-28 22:42 BST+0100
https://linustechtips.com/topic/1516183-help-me/#findComment-16009951
It would not be good for you to go next Gen in your budget range. Doing this would seriously downgrade the GPU. The build is perfect as is and making any changes to it would not be advised. I have the Intel build for you here below but I strongly recommend the AMD build for better compatibility and the overall CPU performance of the 5800X3D. Right now it's 2nd best CPU for gaming if you are not going next Gen (AM5) 7800X3D. If you get my AMD build them there will be no need for a PC upgrade for at least 5-7 years.
Remember you can DM me if you have any more concerns and I can give you my info.
https://uk.pcpartpicker.com/list/3dd6v3
CPU: Intel Core i5-13400 2.5 GHz 10-Core Processor  (£209.99 @ Amazon UK)
Motherboard: Asus TUF GAMING Z790-PLUS WIFI D4 ATX LGA1700 Motherboard  (£226.98 @ Amazon UK)
Total: £1600.20
https://linustechtips.com/topic/1516183-help-me/#findComment-16009977
