So i clip a lot of footage from various games, and this issue is on each one of them
having 7900xtx AV1 encoder VS my old 6750xt H265 encoder has brought some serious issues (to me at least)
when i clip somehing and go open the clip, its either only audio or doesnt get past 1 frame, progress bar keeps going but freezes video after 1 frame
however when i click to a any point on the progress bar it shows the frame of what it should be, and not the frozen frame, its like the video is there but you cant watch it unless you click each and every frame
anyone else with this issue?
Sapphire Nitro 7900xtx paired with 32gb ram 3200 and 5800x3d, all games
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1515816-7900xtx-av1-encoder-issues/
What are you opening with? You need a player which supports it.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
windows media player
photos
VLC
Setup:
photos
VLC
What about OBS?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Yeah, unfortunately the AV1 encode is one of the things being implemented still. I think YT and other streaming platforms have implemented it properly, players not so sure. VLC should have support, but not sure how good
AMD driver side could be the issue, AV1 is rather new thing.
1 minute ago, filpo said:
What about OBS?
i dont record with that, only use it for streaming
i use amd recording
Setup:
well tbh i did have to rma the gpu since it had artifacts, maybe that was also not working correctly.
still weird that video is technicaly there but not when regularly playing
Setup:
Atrifacting? Are you sure its hardware related, not drivers being raw?
I get artefacts in specific scenarios, not overall corrupt pixels regardless of the scene. Also, I have seen people report weird texture glitches due to decompression done on CPU instead of GPU.
So many added points of failure in the chain again...
But hopefully the new unit is ok
new unit hasnt shower up yet bc the delivery service is delayed
ugh
why now of all times
heres the artifactibg btw
Setup:
ugh
Yeah, that does look like some hardware artifacting. Good luck with your RMA 🙂
I run my card at stock AMD settings right now. Not gonna raise any conspiracy, but could also be some weird glitch because of OC BIOS cant control memory. But thats just pure speculation, based on different BIOS...
