Hello just started to put together my first build and I connected by Corsair ll120 fans which needed to be connected to a 2.0 internal usb drive now I’m trying to install my Corsair rgb elite cooler and that also has to be connected to a 2.0 usb drive which I don’t have anymore I’m running the asrock z790 steel legend wifi motherboard there is another usb 2.0 in which I connected the top usb drive to any info helps
https://linustechtips.com/topic/1515238-problem-not-enough-usb-20-internal-headers/
then you search for a NZXT internal usb hub and get 4 out of 1..
https://nzxt.com/product/internal-usb-hub-gen-3
it has magnetic backplate so easy to stick somewhere it's space in your build.
it demands a spare sata power port, but it's an extention that comes with it if you need that.
