Help with build
Go to solution Solved by filpo,
2 minutes ago, Dlzluka27 said:
Thanks for you guys solutions i will definitely follow your builds
Go for this sorry edited
PCPartPicker Part List: https://be.pcpartpicker.com/list/DwZ9hk
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (€192.95 @ Megekko)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler  (€38.85 @ Megekko)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (€109.00 @ Paradigit)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€68.85 @ Megekko)
Storage: Crucial P3 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€53.95 @ Bytes At Work)
Video Card: ASRock Phantom Gaming OC Radeon RX 6950 XT 16 GB Video Card  (€656.95 @ Azerty)
Case: Deepcool CC560 ATX Mid Tower Case  (€63.39 @ Azerty)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€123.85 @ Megekko)
Keyboard: Glorious GMMK RGB Wired Gaming Keyboard  (€57.94 @ Azerty)
Mouse: Razer DeathAdder V2 Wired Optical Mouse  (€39.90 @ Megekko)
Total: €1405.63
Generated by PCPartPicker 2023-06-20 13:53 CEST+0200
Budget (including currency): 1200-1300 includ. Keyboard and mouse.
Country: Belgium
Games, programs or workloads that it will be used for: Gaming: fps and some graphic games. Music production and light video/photo editing.
https://linustechtips.com/topic/1514390-help-with-build/
Country: Belgium
we already answered your question...
why make a new one?
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995895
Just now, Dlzluka27 said:
Well i haven't fully found what fits me so i'll just start from scratch. Just looking for a build that fully fits in my budget.
the one by @filpo should do just fine
its litteraly the best hardware for the money
u cant get a better deal
Setup:
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995900
4 minutes ago, Dlzluka27 said:
I really like the build but + keyboard and mouse it wil gonover my 1300 budget
how come? its included in the budget
oh wait nevermind...
Setup:
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995910
Go for this then, still a bit over but is good
PCPartPicker Part List: https://be.pcpartpicker.com/list/ZKbTd9
CPU Cooler: Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler  (€78.85 @ Megekko)
Video Card: Gigabyte GAMING OC Radeon RX 6800 16 GB Video Card  (€575.95 @ Bytes At Work)
Keyboard: Logitech G413 SE Wired Gaming Keyboard  (€69.90 @ Megekko)
Mouse: Logitech G305 LIGHTSPEED Wireless Optical Mouse  (€52.90 @ Megekko)
Total: €1389.59
Generated by PCPartPicker 2023-06-20 13:46 CEST+0200
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995916
i was able to make a list for 1400
if it nees to be 1300, i can switch out gpu for another, wich means youll get WAY less fps, as least 30%
PCPartPicker Part List: https://be.pcpartpicker.com/list/R6jBsL
CPU Cooler: be quiet! Pure Rock 2 Black CPU Cooler  (€46.85 @ Megekko)
Keyboard: Corsair K55 RGB PRO Wired Gaming Keyboard  (€62.85 @ Megekko)
Mouse: Cooler Master MM720 Matte Wired Optical Mouse  (€24.90 @ Megekko)
Total: €1403.54
Generated by PCPartPicker 2023-06-20 13:48 CEST+0200
Setup:
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995921
Total: €1389.59
that cooler is overkill
a simple pure rock 2 will keep it at 60° and under
same for the logitech stuff, its ok, but overprice, for mice i much prefer coolermaster
Setup:
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995923
please mark the build as solution ihstead of your own comment
Setup:
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995931
Total: €1405.63
Total: £1040.95
https://linustechtips.com/topic/1514390-help-with-build/#findComment-15995932
