Complete BSOD Mayhem - Help! [SOLVED]
Go to solution Solved by Krizzzzz,
The problem is solved after reseating one of the DDR5 DIMM's.
Hi Everyone,
I have just finished building my first ever PC all by myself and actually went by Linus' Build guide. It worked very well yesterday and today I played some games and everything was running like a dream.
Then I went to Restart the PC for some windows update and it booted to a BSOD. It gets stuck in a reboot Cycle and always ends up in a BSOD, but its always different:
IRQL_NOT_LESS_OR_EQUAL
PFN_LIST_CORRUPT
CRITICAL_PROCESS_DIED
MEMOY_MANAGEMENt
among others, I couldnt catch all o them. I also tried the onboard Graphics to see if it was the GPU but no luck - same problem
Now I cant even do anything, not even BIOS. The computer WILL freeze after about 30 sec.
 Its just enough time to get to the windows login screen and it freezes. I can do something in BIOS but it will inevitably freeze. And as such I cant reinstall windows.
I updated the BIOS before installing windows...
please help anewbie Builder not to get eternally traumatized by his fist Build- thanks, Kristian
  • Win11 fresh install
  • x86 (32-bit) or x64 ? - Unsure?
  • Installed using Windows media creatio tool USB device
  • Age of system: Brand new, except for GPU which was purchased second hand
  • CPU: Ryzen 5 7600
  • Video Card: Rx 6800 XT
  • MotherBoard - MSI B650 Pro Wifi
  • Power Supply - BeQuiet System Power 9 - 700w
  • System Manufacturer: Myself
  • Desktop
https://linustechtips.com/topic/1513404-complete-bsod-mayhem-help-solved/
Could you go into Event Viewer then proceed to go to Windows Logs > System
Sort the logs by date (most recent to oldest) and could you tell me if you see a lot of errors?
If so, could select them and export the events, it might help in troubleshooting your issue.
To export the events, select the errors you see, Action > Save selected events...
You will then be asked to give it a name.
In the meantime, make sure all your drivers are up-to-date. Do not use programs such as “driver easy”
Make sure you download the drivers from the OEM's website yourself.
