19 minutes ago, Chuckelor said:
Budget (including currency): 200000 JPY
Country: Japan
Games, programs or workloads that it will be used for: Blender
Other details some gaming on Steam
Doing what with blender?
The obvious answer to your query is: the most powerful Nvidia GPU with the most VRAM (blender supports AMD, Intel and Mac but not very well, CUDA and Optix are still the best performing & stable options), the most system RAM you can get and the most powerful CPU with good multi core performance.
Anything else you want will depend on your workflow/ productivity type.
Try lookng at Puget systems for thier graphics workstation builds and choose a system based around those but within your budget and suiting your projected workload.
https://linustechtips.com/topic/1513295-pc-build-for-blender/#findComment-15987648
Country: Japan
PCPP is only going to provide Newegg Japan pricing which is not the best. Do you have any local computer store with decent english version? Id love to help.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1513295-pc-build-for-blender/#findComment-15988885
  • 2 weeks later...
It's not that Newegg Japan's pricing is bad. It can be comparable to some of the major e-retailers like Amazon Japan. It's just that returns are handled by Newegg US.
Question to @Chuckelor
1. Do you mind used hardware?
2. Would the budget exclude monitors and peripherals?
3. Do you mind if the parts are ordered from different retailers for a better price?
AMD Ryzen 5 3600 | AsRock B450M-Pro4 | Zotac GTX 3070 Ti
Shure SRH840A | Sennheiser Momentum 2 AEBT | LG C9 55"
https://linustechtips.com/topic/1513295-pc-build-for-blender/#findComment-16004025
