Simple M2 installation question
By
BunnyKraken
in Troubleshooting
in Troubleshooting
Solved by Lurick,
Yes, leave the pad that's already there on but don't install anything else.
The Kingston drive you mentioned is double sided by the way.
Everything else you said is correct and no it doesn't matter about the existing pad not being fully aligned, it's fine
Packhunter ·
Posted in Graphics Cards0 -
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies1 -
Airmack ·
Kyle89 ·
Posted in Troubleshooting2 -
8
5
ken43 ·
Posted in Troubleshooting5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
