Flash guard
Go to solution Solved by Guest,
i think the flash guard you heard of is flashgard which is a brand for a screen protector, and from my little research i think flashgard is a hydro gel screen protector. so i would go for whatever you prefer if you want more protection then tempered glass if you just want to prevent scratch then hydro gel is good enough
https://linustechtips.com/topic/1512809-flash-guard/#findComment-15989007
Does hydro gel protects when phone falls down or it is just for scratch resistant
https://linustechtips.com/topic/1512809-flash-guard/#findComment-15989025
