looking for portable solar battery bank under 140$ usd for camping
17 minutes ago, gergory117 said:looking for a battery bank for a 10 day camping trip soon i only need to charge my phone off of it so i only need usb ports
Are you going to rely on the stored energy for the entire duration of the trip, with only solar as your source?
assuming so, just some realistic numbers here.
if you want to heavily use your phone the whole trip, aka watch videos or game the entire time, you are going to need 300wh of energy in total assuming you want to leave with a full phone battery, 30wh a day or roughly 1.5 phone charges.
If you just want to use the mobile sparingly, only for map use or whatnot, I think you can get by with 100wh or less.
If you are going the sparingly route, I would get two power banks rated at 25,000mah from a reputable brand, and if you have time, test at least one to see how many charges you get from it.
if you are going to heavily use it route, I would get one power bank and a 15w foldable solar panel. Keep in mind you will need ~3-5 hours of cloudy imperfect daytime if the bank is completely dry, or ~2.5 if perfect clear skys, so if that is a problem, just go with a bigger panel size.
