First Pc Build
Go to solution Solved by Why_Me,
3 minutes ago, DrDefine said:
is a i7 4790k better cause thats what i have
The 5600 is better.
5 minutes ago, DrDefine said:
That's normal. Unless the box you get says "Ryzen 5000 Series Ready," then you'll have to flash the BIOS before you will be able to post with that cpu & motherboard combo. I would recommend the MSI B550 Tomahawk MAX Wifi motherboard instead tbh.
https://pcpartpicker.com/product/MfZ9TW/msi-mag-b550-tomahawk-max-wifi-atx-am4-motherboard-mag-b550-tomahawk-max-wifi
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1511649-first-pc-build/#findComment-15975525
Thanks so much 👍 is the normal tomahawk good cause im trying to save some money {i will use ethernet}
https://linustechtips.com/topic/1511649-first-pc-build/#findComment-15975546
I see how you got lead into these parts, but for a first build, it's truly not that bad at all. Generally swinging in the right direction, but having a few misses.
Here is how you will be A LOT happier with the system:
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($129.38 @ Amazon)
Motherboard: ASRock B550M Steel Legend Micro ATX AM4 Motherboard  ($129.99 @ Amazon)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($109.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($59.99 @ B&H)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6750 XT 12 GB Video Card  ($369.99 @ Newegg)
Case: Fractal Design Focus 2 ATX Mid Tower Case  ($79.98 @ Newegg)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Newegg)
Total: $999.31
Generated by PCPartPicker 2023-06-07 17:10 EDT-0400
Why the corrections:
The CPU - Ryzen 5000 series is MUCH better than 3000. The 5600 and 5600X are basically identical in performance and the 5700X is only 10% faster on average than them, so for anything under 5800X, the 5600 is a great choice. It also comes with descent stock cooler, which works more than well, so no need for an expensive AIO.
The Memory - idk why would you need 32GBs of it, but there it is with the sweet spot for Ryzen 5000 CPU - 3600MHz. I'd personally save money and go with 2x8GBs.
The motherboard - it is basically a tier higher than the Asus, but currently everything is better than an Asus board. Asus have MUCH deeper and bigger problems as company than just exploding boards and badly put together GPUs. They are on a serious downward rollercoaster atm.
The NV2 series of SSDs from Kingston is terrible., Slow and with poor reliability. The OG 970 Evo Plus is more than enough for that system. If you are keen on the SSD being PCIe Gen4, the Samsung 980 Pro is just $7 on top of that.
The GPU - the most important part. it's basically a tier up than the 6650XT and the best choice for under $450, let alone under $380.
The PSU - 850W is more than enough the handle the system and 1000W is an extreme overkill here.
So yeah, this will make you A LOT happier.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1511649-first-pc-build/#findComment-15975802
No, you will need the MAX motherboard, as it will come with Ryzen 5000 series ready BIOS.
You can go this route.
https://pcpartpicker.com/list/GhjGW4
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($148.99 @ Amazon)
CPU Cooler: Cooler Master MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($79.98 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard  ($179.99 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($81.99 @ Newegg)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($50.99 @ Amazon)
Video Card: MSI MECH 2X OC Radeon RX 6700 XT 12 GB Video Card  ($339.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair RM1000 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $0.00)
$976.92
https://linustechtips.com/topic/1511649-first-pc-build/#findComment-15975872
