I really like the design for the Deepcool LT series. But I'm not sure if I should get the 520 or 720 model. Both are on sale and decently priced.
I live in a hotter climate and need the best cool possible.
Does the R7600x neeeeeed to hit 95*c in order to hit maximum clock speeds? or will keeping it cooler help it?
I want a AIO for this build. going to put it in the Deepcool ch510 mesh/digital.
https://linustechtips.com/topic/1511059-deepcool-lt-for-7600x/
Are you saying that it has to hit tJmax before it can clock to its full potential? its actually the opposite. I.e. the lower the temperature, the more leeway it has to boost higher. So a better rad would be better. But since both f these are very competent I would say it doesn't matter too much and you don't need to spend more on the 360 mil ls720 since the 7600x can be tamed on a good single tower cooler (somewhat tamed) like the nh-u12s redux
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1511059-deepcool-lt-for-7600x/#findComment-15970760
From what I been hearing is that they need to hit that 95*c in order to maximize performance and they can stay at that 24/7. But if your correct then low the temp the better and it will still hit the max performance.
https://linustechtips.com/topic/1511059-deepcool-lt-for-7600x/#findComment-15971169
It doesn't need to hit 95 degrees C. The lower it is the better (when its under full load) because then it'll be hitting its max performance at a lower temp. But I would get the double 120 rad
Total: £1040.95
https://linustechtips.com/topic/1511059-deepcool-lt-for-7600x/#findComment-15971668
