Budget (including currency): $960
Country: USA
Games, programs or workloads that it will be used for: Fortnite, Apex Legends, Valorant, Roblox, X-Plane 11, MFSF, and editing in HitFilm
I need a keyboard and mouse don't have one rn and will also need a monitor I would not like to exceed my budget and I would like to play at 1080p high or 1440p low/med resolution would also need to have some decent speakers and my theme is Black and white please help me
https://pcpartpicker.com/list/4g9NRv
https://linustechtips.com/topic/1509265-need-help-finalizing-the-pc/
The only thorn in here is the case and the mouse. 2$ extra would net you a Fractal Design Focus 2 which are going to be easier to build and has better airflow, and you can throw in Arctic P12 later on for exhaust for 10$, and Newegg is currently running clearance on windowless Pop Air (which is in this list) for 50$ if you dont mind it. For the mouse, Deathadders especially those non optical ones from back in 2013-2020 is insanely unreliable. Youre purchasing this in US right?
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($99.00 @ Amazon)
CPU Cooler: Thermalright Burst Assassin 66.17 CFM CPU Cooler  ($27.90 @ Amazon)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($106.99 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($49.97 @ Amazon)
Storage: TEAMGROUP MP33 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($69.99 @ Newegg)
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card  ($239.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($62.98 @ Newegg)
Power Supply: Cooler Master G700 700 W 80+ Gold Certified ATX Power Supply  ($79.99 @ Newegg)
Monitor: AOC C24G1A 23.6" 1920 x 1080 165 Hz Curved Monitor  ($119.99 @ Amazon)
Keyboard: G.Skill KM360 Wired Standard Keyboard  ($49.99 @ Amazon)
Mouse: Cooler Master MM711 Matte Black Wired Optical Mouse  ($24.99 @ Amazon)
Custom: KBEAR KS2 in Ear Monitor,Stereo Bass Headphone, Yinyoo HiFi Over Ear Earbud Headset Noise Cancelling Hybrid 1BA 1DD Earphone with Removable Cable for Running Walking,Church,Stage(no mic, KS2  ($24.99 @ Amazon)
Total: $956.77
Generated by PCPartPicker 2023-05-25 21:34 EDT-0400
If you can afford 10$ extra id definitely get the pro version of the SSD.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Total: $956.77
I ald have a headset and yes i live in the us
