I just enabled Hyper-Threading on my CPU. I was told that this would increase performance by 30%. This was false. It instead decreased performance by like…50%! I’m running RPCS3, the PS3 emulator that by all means should work badly on my dumb i7 2600. But it actually worked very well. And as soon as I turned on hyper-threading, everything went to crap. 45 FPS with it off, 20 FPS with it on! So what the hell is going on here?! What’s wrong with my PC, and how the hell do I make hyper-threading actually do what is should: make the game play better!
I exist...
https://linustechtips.com/topic/1509220-hyper-threading-worse-fps/
In normal games you will should see a nice performance boost. An emulator is weird in so many ways, especially the ps3 emulator.. The ps3 was an absolute NIGHTMARE to make games for! Absolutely terrible, so THIS particular program might not work well with hyper-threading.
I was told by the discord it would help, but still nothing. There must be some setting that I’m failing to find. If not, then I suppose the discord is wrong. I have set the SPU and PPU threads low since that helped with stuttering. That could be it. Maybe there’s something else…
I exist...
That i7 is 12 years old, that alone is not a great recipe for emulation. Secondly hyperthreading would have been on be default, that's what give your 4 core CPU 8 threads. Did you turn it off at some point?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
I never turned it off. I had changed the CPU to this, and my old one did not have hyper-threading. This CPU is actually the best my motherboard can handle.
I exist...
@Zac_The_Dude
Does the Task Manager Performance tab show 4 cores and 8 logical processors?
If you swapped in a different CPU it might only be showing 2 cores and 4 logical processors. If you have this problem, run msconfig, click on the Boot tab, press the Advanced options... button and make sure the Number of processors box is not checked. Reboot after you do this.
Hyper threads are about 20 percent performance of a core, emulator doesn’t no what is a hyperthread or core
so any workload pushed to them tanks
Normal pc gaming is fine because games will know what is what and assign light work loads to them
-14900kf
- 4000 32gb ram
-4070ti super duper
It's possible you bought a "questionable" CPU.
One thing to check, see if you can do core pinning in software.
https://www.google.com/search?q=rpcs3+hyperthreading
It does look like for your specific use case there might be issues.
As a rule of thumb hyperthreaded squeezes around 20-30% more performance out of a core and there's only very rarely a downside.
You'd have probably benefitted more from going with a used, more modern system though. There's some very cheap refurbished office systems out there.
5900XT (16C/32T) | 64 GB DDR4 RAM | RTX 5070
1.5TB Optane P4800X | 16TB nvme SSD NAS w/ 10Gbe & 96GB DDR5 RAM caching
LG C4 + QN90A | Sony AZ7000ES | Polk R200+R100, ELAC OW4.2, SVS PB12-NSD + 3x SB1000 | HD800
