DDR5 - 5600 128GB (32x4) Not Booting at correct speed - AMD XPO (R9 7950x)
3 hours ago, Hinjima said:Its strange you say that its at 3600mhz.. It shouldn't go lower than 4800mhz because thats the default speed. Are you sure you are reading correct? Where do you see the 3600mhz speed?
3600MT/s is the highest officially supported speed on 7000 series AMD when using 4 sticks. It's shockingly low, I know.
3 hours ago, BryBry said:The title sounds like I havent simply gone into the bios and turned on XPO or XMP or whatever AMD uses for 7th gen ryzen. But I cant seem to even Post past DDR5 3600
On the spec sheet of the CPU you can see that 3600MT/s is the highest officially supported speed for this CPU when using 4 sticks. Under Connectivity, look at 4xR1 and 4xR2 which means 4 sticks of single or dual rank memory (Not to be confused with dual channel which is completely different).
Updating the BIOS is really the only thing you can try for getting EXPO to work. If that does not help you could try manually input the speed and timings (I have never dealt with the Infinity Fabric so clocking that separately might help, really uncertain). Final solution would be getting a stick off the QVL for the board that was verified to work at at the desired speed.
This is not guaranteed either as memory manufacturers will use different components for each batch if they can get it cheaper from a different supplier and the components from the other supplier might be different enough that it doesn't work. The QVL will usually tell you which vendor was used with the tested kit and which die (Chipset version) it used. This is not really helpful when buying as no one lists who made the chips on the packaging/website for that batch. All RAM (Mainstream at least) has components produced by either Samsung, SK Hynix, Nanya or Micron/Spectec.
