MSI MPG Z690 Carbon Wifi Motherboard : ARGB/RGB port not working
I used MSI MPG Z690 Carbon Wifi motherboard with Core i5 13600KF since December 2022. Bios version was updated till January 2023. GPU Asus ROG Strix LC RTX 3080 Ti.  I am using Corsair Obsidian 1000D Case which supports 21 Fans with 3 Radiator. I got all 21 ARGB Fan installed, also installed some additional RGB strip Leds. All works perfect.
A week ago i changed the motherboard as i got another Asus Rog Strix Z690-E Gaming Wifi. Unfortunately that Asus motherboard (Updated Bios) have RAM compatibility issue, i tested with G.Skill D5 (5600MHz) ram but unable to run 2 stick at a time, no matter what slot i use (A1, A2, B1, B2) it showed Q Code 55 error. Single stick works but speed stuck at 4000MHz. With XMP Enabled, bios shows 5600MHz but in windows system and all software shows 4000MHz. I also tried with Kingston Fury D5 (6000MHz) but exactly same result. Tried by reinstalling OS W10 Pro but no lucl. All RGB & ARGB ports works just fine with Asus motherboard.
So i roll back to previous MSI motherboard. Did not change any setup in the build just swapped the motherboard. Before boot, i did update the bios through motherboards rear usb (bios updater) port. When i tried to boot all works fine except RGB & ARGB !!! I tried all possible solution by searching the web including bios rolling back to previous version, clear CMos, replug all the ports & Power, OS Setup, Physical Led switch on/off etc etc etc. But its not working!!! When i tried to install & launch Mystic Light it did not launch and says "this platform does not support this application".
I have no idea whats the issue!!! I just swapped the motherboard, Nothing else !! I will not continue with this motherboard if i cant able to use RGB/ARGB.
Need experts opinion on this, should i change the the motherboard? Or any solution to fix this issue!!
