PC making a noise recently but can't identify which is causing the sound.
Solved by Galahal,
With bit more manual checking of each case fan and GPU fan, I found the exact same issue. Same Variant card mine is 3070 Ti Aorus Master
https://www.reddit.com/r/gigabyte/comments/r90vza/aorus_3080_master_v1_fan_1_spins_at_100_fan_3/
GPU FAN 1 is at 100% all the time HWinfo or other fan control app shows 0 RPM
Featured Topics
MiszS ·
Posted in Power Supplies0 -
NukoTi ·
Posted in Troubleshooting5 -
1
Xenny ·
Posted in New Builds and Planning1 -
3
1
KazBoy1412 ·
Posted in General Discussion2 -
6
Fat Cat11997 ·
Posted in Graphics Cards5 -
1
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
