Gigabyte Aero-16 XE5 doesn't charge via Power Delivery.
1 hour ago, HeRobrain_3 said:Thanks to your answer, I found out the issues:
For the battery bank, I need to press the main button (I didn't need on my other laptop). <-- Solution by leclod
For my 100w wall charger, this laptop isn't compatible with this 112w charger: Link to the charger page (Best Buy Canada)
For the phone charger, too low watts. Need >60W. According to this page : https://www.gigabyte.com/ca/Support/FAQ/4300
Your 100w wall charger supports PPS but nothing is written about PD, so probably no PD support, which is surprising.
For the phone charger, the issue is more about Vs than Ws, your phone charger probably only delivers 5V while the notebook wants at least 9V or 12V (not sure which).
I did manage to charge a notebook with my 30W PD wall charger (up to 20V) and via my 18W PD PB (up to 12V)
(I did forget about the cable compatibility issue)
