Hello. I wanted to buy an Xbox controller for my PC. Probably an Xbox One S/X or series controller. I prefer to use the controller wirelessly via Bluetooth. I've heard that the vibration doesn't work over Bluetooth and I have to connect the controller with USB or use the Xbox wireless dongle. I just wanted to know if it's the case and if it is, is there any way to use vibration on the Xbox controller using Bluetooth?
https://linustechtips.com/topic/1506900-xbox-controller-vibration-over-bluetooth/
My XBOX One controller has vibrations over bluetooth, I am connected to my motherboards WIFI antenna ( works as a bluetooth reciever ) instead of a dongle, shouldnt matter though.
It's a relief that it works fine.
Thank you for your help.
