Asus FX505 -GE PROBLEM!!
Solved by jaslion,
You did all the steps if it still does that with all the stuff out that pretty much means something broke on the board. Which would only be fixable/traceable by people with knowledge of this as thats not that easy to figure out. (well technically it's just a HEAP of carefull probing with a volt meter).
Replacing the broken part is another big thing that is hard if it can be found.
I do gotta ask whats up with that keyboard. It's gray and thats not normal for any 505. Was that modified?
Best case the power button is causing a issue maybe but I doubt it as it's power cycling which usually means death for a laptop.
