Recently bought a switch 810. It's got the 4 stock fans (front, top, rear and internal) plus my stock 240 (think that's the size) on bottom. My 4 switch fans are set to 1k with my 240 set at 800 via my LXE. Are they needed this high or do I need them lowered. Only asking as I've read people on here claiming much lower rpm for fans and mine seem way higher.
 Motherboard  ROG Strix B350-F Gaming | CPU Ryzen 5 1600 | GPU Sapphire Radeon RX 480 Nitro+ OC  | RAM Corsair Vengeance DDR4 3000MHz 2x8Gb | OS Drive  Crucial MX300 525Gb M.2 | WiFi Card  ASUS PCE-AC68 | Case Switch 810 Gunmetal Grey SE | Storage WD 1.5tb, SanDisk Ultra 3D 500Gb, Samsung 840 EVO 120Gb | NAS Solution Synology 413j 8TB (6TB with 2TB redundancy using Synology Hybrid RAID) | Keyboard SteelSeries APEX | Mouse Razer Naga MMO Edition Green | Fan Controller Sentry LXE | Screens Sony 43" TV | Sound Logitech 5.1 X530
https://linustechtips.com/topic/150615-fan-speed-help/
depends on ur cpu and gpu temp...if they r spiking then increase the rpm otherwise keep it as it is... :)...and if u r getting good airflow then turn them down and then switch to max when u r doing some heavy work..
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012349
As long as your temps are fine, you can go with whatever rpm you'd like.
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012372
Thanks for your replies, guess I can lower them then. Temps are decent atm. Should I move my internal (one of the directional fans on the switch) to the front so I've got 3 in 2 out? Positive airflow is better, right?
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012400
Positive airflow should theoretically help keep out dust.
Similar situation to before--configure your fans however you'd like as long as your temps are fine. Try it out and see how it goes.
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012409
Thanks once again. Try it out when I get in on a few hours and report back :-)
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012437
ya u can do that...positive airflow is better and just clean all the fans once in a while... :)
https://linustechtips.com/topic/150615-fan-speed-help/#findComment-2012484
