Hello, there is a random CMD flash that Alt tabs me for 1 sec, I don't get to see it clearly, the end says appdata/roaming/rcceiei
I tried to delete everything from the appdata file but pc doesn't let me delete 3 of the files inside, any help or suggestions? Tried malwarebytes and did nothing
https://linustechtips.com/topic/1506037-desperate-for-help/
I'll usually find the process I'm looking for in Resource Monitor or in Task Manager and terminate it. If its not letting you delete it because its currently executing, then that'd be the way to un-alive it to delete it.
Otherwise if you're concerned about malware, I'd recommend a fresh install 🙂 Easiest way to be-rid yourself of malware. If you don't have the rights to delete it in your current login, booting into safe mode and doing it there can be enough.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1506037-desperate-for-help/#findComment-15932784
Go into Safe mode, you can delete the files there. If you can't see the whole thing, turn on Show Hidden Files & Show System Files in Folder Options.
Also make sure you delete the startup entry as well.
https://linustechtips.com/topic/1506037-desperate-for-help/#findComment-15933291
