Hi guys,
So, loving my new 780 and the 3 Dell U2414H's I picked up shortly after to get toward my dream setup. (long time saving!) :)
Then comes the joys of nVidia surround.
My impressions so far are that:
- The experience in games is amazing, much more immersive.
- The desktop experience is, well, really just annoying and in your way. Like Eyefinity (from what I've heard/read), they need to have more options on window management (ie. aero snap behavior).
- It's a bit of a ball ache and something nVidia seriously need to invest a bit more time into.
The farce to change (can't stand the desktop in being in surround) from surround back to extended is seriously annoying, having it re-arrange the desktop, and it auto disconnecting the other monitors every time you switch off surround is a real pain (having to re-enable them in windows screen settings).
My question to you guys:
Is there an easier way to switch from surround, back to having the 3 separate monitors in extended? (have it not disconnect the displays, keep desktop layout, etc.)
Thanks. :)
https://linustechtips.com/topic/150512-surround-to-extended-fix/
Have you thought about "Display Fusion"?
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011015
Yeh, have it installed for around 5-6 months now. Got it in a steam sale.
It's great for applying wallpapers and fixing a few gripes with window management & saving desktop icons. But as far as I can see, it unfortunately cannot switch between surround/extended in a better manor, if at all.
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011060
Hmm, couldn't you just keep it in surround mode and then use display fusion to create virtual screens. I.E 3 x 1920x1080 screens as one profile and then a second profile set to 5760x1080 for gaming.
I've not used display fusion enough to understand it much. I do fine with my surround setup (yup it's a ball ache).
Linus did a
on display fusion which does highlight a lot of good points and features. Perhaps that will assist you better??
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011088
Linus did a video on display fusion which does highlight a lot of good points and features. Perhaps that will assist you better??
Thanks, I'll give it a watch. :)
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011129
No problem  :lol:
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011140
@MysteriousKiwi
Ah, that's a shame. I was hoping that with virtual monitors through DF it would behave the same as extended?? without the hassle of disabling and enabling  :huh:
https://linustechtips.com/topic/150512-surround-to-extended-fix/#findComment-2011314
