Need help bad
Go to solution Solved by Blqckqut,
look up the manual and look for argb gen 2 header
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1504847-need-help-bad/#findComment-15924007
7 minutes ago, AfJerb said:
Yes it is but the problem was that my aio fans were 3 pin and not 4 pin with one missing. I ended up just plugging them into Sata and changing rgb manually
You mean the old GDV 3 pin? That's ironic, as I believe Gigabyte were the ones who tried to popularize that standard, and failed. Some of their old boards have a header for that.
Did you buy that AIO new or is it an old one? I'm surprised anyone would be selling new aRGB fans using exclusively a GDV header. Some have both, but I haven't seen one with just GDV in a while.
https://linustechtips.com/topic/1504847-need-help-bad/#findComment-15935944
Did you guy that AIO new or is it an old one? I'm surprised anyone would be selling new aRGB fans using exclusively a GDV header. Some have both, but I haven't seen one with just GDV in a while.
I got a new one and no I got no headers. I might just buy new fans later on and switch them out
https://linustechtips.com/topic/1504847-need-help-bad/#findComment-15935946
