Epyc of some sort would be my suggestion
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1504292-cpu-selection-help/#findComment-15919476
