need gpu help
By
christopheruu
in Graphics Cards
in Graphics Cards
Solved by _Omega_,
NVIDIA RTX A2000 is properly the best gpu you could put in there, its close to a 3050 and you can find some good deals on the used market when you are patient.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
