Since 2 weeks ago I have problems with the temperature of the processor.
I have an i5 12600k (without OC) and an MSI MAG CoreLiquid C240 liquid.
When I play games the processor reaches more than 90 degrees and is at 60 at idle.
I have changed thermal paste and I have verified that the pump works correctly.
I have updated windows, bios and drivers.
Could maybe be the motherboard or CPU?
I need help please
https://linustechtips.com/topic/1503873-high-cpu-temps/
MSI Recalls MAG CoreLiquid 240R, 360R AiO Coolers Due to Sediment Build-Up | Tom's Hardware (tomshardware.com)
Edit: I see that you have the C240 version, not 240R. Maybe this (link) is not the issue anyways.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15916168
2 hours ago, eseeselloko said:
I have tried to put my serial number but the page tells me that my product is not compatible since it is only for the versions 240R / 360R and i have the 240.
I have also contacted them. Any other idea? 😞
is one tube warmer than the other tube?
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15916962
20 minutes ago, eseeselloko said:
Yes, a lot more. But it's normal right? I want to think that the hot liquid passes through one tube and the cold through the other
yep. that means the pump is working..  and i will asume entry and exit ports of the radiator has about the same difference?..
back to the issue.. did you have any updates around 2 weeks ago when you noticed cpu cooking?   or do any changes?
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15917181
I don't see anything obvious that indicates that it is wrong.
I have seen in this video at minute 11:25 that if one tube is much hotter than the other it means that the pump is dead
That's true?
In my case, one tube is much hotter than the other
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15917196
That's true?
the logic is.. if it's a difference.. fluid is flowing... flowing hot to the radiator to get cooled down by the fans as it flows through the ribs.. hence.. the return tube is cooler.  the difference is probably because there is some movement..  altho he says it is disconnected..  by logic, it heat should spread equal to each tube. if the water is standing still..  on the other hand, the difference shouldn't be as high as it is here, since the liquid will have some heat..
i'm running a custom loop myself as i don't realy trust AIO's.. and think they are too small too often. up to latlely you couldn't monitor liquid without opening the loop and connect an inline temp sensor.
now you have some with liquid temp in the display mounted over the cpu. or in software from the vendor.
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15917199
I plugged the pump connector into a CPU_FAN to see if the pump was dead, but no, it was running at 4000rpm.
I have bought another AIO and it arrives in 2 weeks. I still have a bad time with the new one, I'm going to return the processor and get another one under warranty.
Thank you very much for the help!
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15917474
The pump might be dead, even though it is still spinning, it could be broken some other way. There could also be a weird fan curve in the BIOS stopping the pump shortly after it is connected. There could also be air in the pump. Try tipping the system so the pump is fully below the radiator and see if that changes things.
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15919471
The pump is already completely below the radiator. I have the Lian Li PC-o11 Dynamic and the radiator is on the top of the case. I have gone into BIOS setup and everything was fine. I have updated the BIOS and I have reset the factory values just in case and it continues to go wrong. The new one arrives in a week. I hope it works well.
I have also found this video (https://www.youtube.com/watch?v=9U_5aGf0G9Q) where the problem is identical to mine and at minute 20:30 it shows what happens. When I get the new liquid refrigeration I will disassemble the one I have now and see if it is the same.
Knowing that the pump could be dead in another way makes me quite happy because I no longer know what it could be
https://linustechtips.com/topic/1503873-high-cpu-temps/#findComment-15919491
