g915 replacement keys
Go to solution Solved by seon123,
15 hours ago, CatXice said:
ye i havnt opened the board yet at all to have a look at it but i assume the leds at inside the switches so it will all come off as one?
The LEDs are separate from, and are attached under the switches, so you won't need to do anything with them. That's pretty much standard for RGB switches, so not sure where they got the idea that you would need to desolder them.
2qfwk1lv0f091.png?width=1280&format=png&
i-wanted-lighter-switches-on-my-logitech
€7.90 per 10 switches is on the expensive side for Kailh Choc switches, afaik. SplitKB has them for €6.99 per 10, including Dutch sales tax (assuming you're in EU)
https://splitkb.com/products/kailh-low-profile-choc-switches
looking to replace some keys on my g915 will standard kailh switches work like these
https://keycapsss.com/switchestester/switches/65/kailh-low-profile-choc-switches-v1?number=KC10034_JA
Thanks
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/1503682-g915-replacement-keys/
23 hours ago, jaslion said:
You are aware these are soldered right? There is a good chance that removing the existing keycaps rips or breaks the traces so whilst it should technically be possible the chance of failure is very real.
i am an electronic eng so i have the tools to do the job without breaking stuff just wanted to know if they will fit or if logitech have made it so they dont
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15916263
they probably will, but if the g915 needs 3 pin switches you can just clip the two black plastic legs to make them compatible
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15916273
just need to be careful when desoldering bc you may need to pull out leds as well
@Bob__ is a w
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15916277
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15916377
Edited by seon123
Something something
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15917036
some boaards have the leds like mounted is the gaps of the switches but ig thats only for older boards without smd components
@Bob__ is a w
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15917105
  Hide contents
€7.90 per 10 switches is on the expensive side for Kailh Choc switches, afaik. SplitKT has them for €6.99 per 10, including Dutch sales tax (assuming you're in EU)
oh the fact the leds are on the board makes the job a 100x easier then (my first time moding a KB) will be a nice easy job as i have all the tools for pcb repair
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/1503682-g915-replacement-keys/#findComment-15917135
