5 minutes ago, SoupSocks said:
I'm looking at a i5 13400F and its $183 US on amazon is that a good deal?
Is it even a decent cpu?
i mean i would go for a 13600kf if you want performance without an igpu
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
https://linustechtips.com/topic/1503248-help/#findComment-15911439
its an ok cpu but no overclocking support and less cores
@Bob__ is a w
https://linustechtips.com/topic/1503248-help/#findComment-15911440
