Budget (including currency): 1500€=1645$
Country: Germany
Games, programs or workloads that it will be used for: Gaming most of the time shooter like Valorant.
Other details: Im planing to buy the PC in 1 month, at the moment i have a screen  that has 60hz, i want consistent 100 fps in Valorant
I have no idea what to buy. Any help is appreciated.
https://linustechtips.com/topic/1503014-first-pc-build/
Country: Germany
PCPartPicker Part List: https://de.pcpartpicker.com/list/rF2CNc
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  (€246.87 @ Amazon Deutschland)
CPU Cooler: Deepcool AK500 ZERO DARK 68.99 CFM CPU Cooler  (€64.98 @ Amazon Deutschland)
Motherboard: *Asus PRIME B650-PLUS ATX AM5 Motherboard  (€191.90 @ Amazon Deutschland)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€115.98 @ notebooksbilliger.de)
Storage: *Kingston KC3000 1.024 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€79.90 @ Alza)
Video Card: PowerColor Red Dragon OC Radeon RX 6800 XT 16 GB Video Card  (€597.99 @ Mindfactory)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (€98.69 @ Mindfactory)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€155.49 @ Amazon Deutschland)
Total: €1551.80
Generated by PCPartPicker 2023-04-25 19:32 CEST+0200
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
https://linustechtips.com/topic/1503014-first-pc-build/#findComment-15909245
https://geizhals.eu/fractal-design-focus-2-schwarz-fd-c-foc2a-07-a2792899.html
Fractal Design Focus 2 ATX Mid Tower Case €67,75
Rear exhaust fan for that case.
https://geizhals.eu/arctic-p12-pwm-schwarz-acfan00119a-a1920124.html
ARCTIC P12 PWM 120mm 4-Pin Case Fan €4,57
https://geizhals.eu/msi-mpg-a750gf-750w-atx-2-4-306-7zp0b11-ce0-a2389531.html
MSI MPG A750GF 750W 80+ Gold Modular ATX Power Supply €115,59
https://geizhals.eu/msi-pro-b760-p-wifi-ddr4-7d98-001r-a2872219.html
MSI PRO B760-P WIFI DDR4 €141,20
https://geizhals.eu/intel-core-i5-13400f-c0-cm8071505093005-a2871161.html
Intel Core i5-13400F €203,22
https://geizhals.eu/deepcool-ak400-r-ak400-bknnmn-g-1-a2721475.html
DeepCool AK400 CPU Cooler €31,64
https://geizhals.eu/corsair-vengeance-lpx-schwarz-dimm-kit-32gb-cmk32gx4m2d3600c18-a2166435.html
Corsair Vengeance LPX DDR4-3600 32GB (2x16GB) CL18 $88.98
https://geizhals.eu/western-digital-wd-black-sn770-nvme-ssd-2tb-wds200t3x0e-a2672116.html
Western Digital Black SN770 2TB M.2 PCIe 4.0 x4 NVME SSD €128,89
https://geizhals.eu/palit-geforce-rtx-4070-dual-oc-ned4070s19k9-1047d-a2930593.html
Palit GeForce RTX 4070 Dual OC 12GB Video Card €625,00
https://geizhals.eu/microsoft-windows-11-home-64bit-multilingual-pc-a2615378.html
Microsoft Windows 11 Home 64Bit €55.89
Total: €1462.73
https://geizhals.eu/aoc-24g2spae-bk-a2697480.html
AOC 24G2SPAE/BK 1920x1080 165Hz 1MS IPS G-Sync Compatible Gaming Monitor €154,89
https://eu.aoc.com/en/gaming/products/monitors/24g2spae-bk
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/black-solid/
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://ark.intel.com/content/www/us/en/ark/products/230501/intel-core-i513400f-processor-20m-cache-up-to-4-60-ghz.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK400-Performance-CPU-Cooler-1700-AM5/2021/15222.shtml
https://www.palit.com/palit/vgapro.php?id=4798
https://linustechtips.com/topic/1503014-first-pc-build/#findComment-15909423
Country: Germany
Do you have a gaming monitor yet?  Any high-end gaming system should have one, otherwise you'll never play at any more than 60fps, and 1080p is kinda sucky if your tower is gonna cost this much.  You can definitely get a 1440p165Hz monitor with this budget.   This will play Valorant at 165fps easily at 1440p:
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€137.99 @ Amazon Deutschland)
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  (€36.18 @ Amazon Deutschland)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  (€109.90 @ Alza)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€66.90 @ Alza)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€85.90 @ Alza)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 XT 16 GB Video Card  (€567.99 @ Mindfactory)
Case: Zalman i3 NEO ATX Mid Tower Case  (€67.90 @ Alza)
Power Supply: NZXT C850 (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€109.90 @ Amazon Deutschland)
Monitor: ViewSonic VX2718-2KPC-MHD 27.0" 2560 x 1440 165 Hz Curved Monitor  (€229.00 @ Amazon Deutschland)
Total: €1411.66
Generated by PCPartPicker 2023-04-25 21:33 CEST+0200
  • The 5600 is plenty fast to run with a 68000xt in any gamer, especially at 1440p
  • The MSi Pro VDH has a ton of ports and headers along with onboard Blutooth aand WiFi, it's a great value
  • The Thermalright Assassin King is a steal for a cooler with 5 heat pipes and a FD bearing fan
  • 32GB of RAM will let you run whatever you want, and you'll never have to upgrade.  3200MHz CL16 should run on any motherboard without a problem
  • 2TB gen 4 NVMe so you can download lots of games.
  • The 6800xt is a fast GPU, but with your budget you could get a 6900xt if you wanted: XFX Speedster MERC 319 Black Radeon RX 6900 XT 16 GB Video Card (RX-69XTATBD9) - PCPartPicker
  • Valorant doesn't need much GPU power, but other shooters do.
  • The NZXT C850 is the same PSU as the SeaSonic focus, its a great power supply.  You only need a 650 or 750, but the 850 was like 1 euro more, so having some headroom is a good deal.
  • The case has good airflow and comes with all the fans you need.
  • 1440p 165Hz monitor so your games look clear and smooth.
  • 100 euros under budget, use that to hget yourself a nice mouse, keyboard, headset, etc.
You could also go for a 4070 instead of the 6800xt for about 80 euros more.  it uses a bit less power and in some games it's faster others its slower.  It has a little less VRAM, but it all depends on what you want from it.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1503014-first-pc-build/#findComment-15909504
1 hour ago, Queen Chrysalis said:
@Why_Me @Bob__ Use the export BB option of PCPartPicker to share parts lists as rich text, it's a lot easier to read them and check the sales webpages that way.
It's Geizhals site, not PC Partpicker.
https://linustechtips.com/topic/1503014-first-pc-build/#findComment-15909529
6 hours ago, OrcaFlunder said:
In 1 month
Then forget it. Whats a deal today will be a bad thing tommorrow, and especially in a month the market would have already shifted a lot.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1503014-first-pc-build/#findComment-15909868
