psu modular cable issue
Solved by OhioYJ,
Honestly I would probably return it if that's an option. As it's going to be an up hill battle to figure out everything, then get cables made, or all the parts to make your own cables. It would really be easier to get a PSU that has everything to begin with.
Otherwise you're going to have to get a meter, turn the PSU on and start mapping it out. You'll have to take some educated guesses on which pins turn it on.
It can be done, but there's lots of ways this can go wrong. Which is why I would just buy a different PSU, it will likely also be the cheaper option too.
Have you tried reaching out to the manufacturer?
