No cpu fan control on Asus a320m-k
Solved by Cacked Lion,
ok so i have now found a solution by increasing the chasis fan curve a little bit and buying a pwm hub so now the chassis fan is plugged into my pwm hub that goes to all the fans at the same time and by going into the bios and ignoring the cpu fan rpm i dont get a cpu fan error, So i think i solved it and my cpu is quiet and cool at a steady 30 degrees even under load
Featured Topics
f4tlframe ·
Posted in Laptops and Pre-Built Systems1 -
Salerene ·
Posted in Networking0 -
Od1sseas ·
Posted in Storage Devices5 -
Darknighterror ·
Posted in Troubleshooting0 -
4
Worstcaster ·
Posted in Displays3
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
