I built a pc with my friend today and since it was my 3rd pc i followed all the steps that used on the other ones ive built but this one had on board wifi and wasnt going to use ethernet once the build had been completed we are now trying to set up the wifi module, the board is the tuf gaming b550 plus wifi ii and we seem to have followed all the steps to set it up and we are up to the part in the windows installation where it asks for wifi or ethernet to continue but we arent able to get the wifi even after restarting multiple times and making sure all the settings in bios were enabled, any help would be apprecatied
https://linustechtips.com/topic/1501969-onboard-wifi-problem-setting-up/
Remember, as soon as you connect it to the net its going to start running windows update and lock it up right away. Update is going to install all the newest drivers for everything, so you will have alot of work to do behind it. Make sure you set up what you can before you hook up the net.
